Resolution problems on GTX 460 :(
24 Apr 2010
I've installed the latest drivers from the nvidia site and my screens native resolution is 1440x900. However the nvidia drivers won't detect this they skip 1440x900 and go to 1600x900 :(
Anyone know a solution.
edit : CSS lets me change to my native, but other games don't :(
Nvidia control panel -----> Resolution
Is it in the list?
If no, press advanced.
Is it in the list?
If no, click customize & make your own.
Using a 470 I see it under the normal windows display options, not even going into Nvidia control panel...
Is it in the list?
Is it in the list?
I have done that and yes it does fix it for windows. But games set their own resolution and in some games it won't appear restricting me to 1280x720 :(
Some games may not support that rez.
have u selected your screen ratio, mine is 16:9 yours might be that or 16:10 or 4:3, u need to select it right to get your required screen res, windows dosent ask for ratio but games do. u need to change i would suspect yo uneed to select 16:9.
