resonating noise
16 Nov 2009
inside your mind
Hi there there seems to be a resonating noise coming from my pc (antec 900) i have a suspicion that its my hard drives
i have got 4 hard drives in 1 cage at the moment, i was wandering if there is a easy way to silence them? or to at least stop that noise as starting to drive me mental :confused:
interesting photos they are. unfortunate i don't have any space in my 5.25 drive bays :( as i have a fan controller and 2nd optical drive...
hmm he sed something about rubber grommets i got lots of O rings somewhere i shall have to try that
thanks for the link diggsy :)
What do you mean you have no room in the 5.25 bays? You have a 900? Surely all you need to do is remove the HDD cage/s and then you'll have free 5.25 bays, no? :confused:
One of my HD's does this, kind of a pulsing vibration which stops as soon as you touch the case.
It used to be in my brothers PC and did the same thing.
I was thinking of putting them in an enclosure like in the link above.
my bad, yeh i got 3 hard drives in the bottom and 1 in the top
so i don't have any 5.25 drive bays now for sure
and it turns out it was my stock cpu cooler....
thanks guys
thanks guys
Yes, but what I am saying is that you can remove the HDD cages and suspend the HDDs in the now freed up open bays. ;)
