- 20 Mar 2017
- UK
HI I've just brought a new motherboard -Gygabyte 990fx Gaming- because either my old motherboard or the cpu was faulty. I'm in the processes of running a prime 95 small fft test with the new motherboard running on default settings -prime 95 tests were failing after about 13mins before- and it seems to be running fine at the moment. I've never done much overclocking before and only recently started using prime 95. I'm running an 8core AMD FX8350 CPU and have the number of cores in prime 95 set to 8 on the torture test. Despite this resource monitor/Task manager only reports the cpu running at 95/6%. I'm also using overdrive to monitor the heat of the cores and overdrive displays them as running at £100%. While running tests with the other motherboard resource monitor also stated that the cpu was only running a 95% but I assumed it was because the board /cpu was faulty.. Is this a problem? I've looked at a few tutorials online that say the cpu should be at 100% for a small fft test, but as I said the test is running fine. Any advice would be great. Sam
