Responsive Web Design Question - 3 images with text underneath question
24 Sep 2007
Hi Guys
What is the best/simplest way to build this with a responsive design:
- On desktop I want a row of three images, each 200 pixels wide by 266 pixels high. Beneath each image I want caption text.
- On mobile browser 320 pixels wide, the images will just be in a column, each with caption text under each one.
I am just trying a ul now, but I am having problems on desktop as if the first li has none or little caption text, then the caption text from the second image will slip underneath the first. How do I stop this?
Thanks
Using inline-block with same mark-up:
http://codepen.io/Dup/pen/reQLjX
inline-block adds an inherent gap between items, so you need to make sure there is no space between the end and start divs.
You can also do this with ol/ul and set the li to inline-block, just remember to reser the passing and margin on the parent to zero.
Calc is also a modern browser function (IE10+). I've used it here with margins purely becasue it's simpler to avoid issues with padding adding to the width of a container.
You can avoid padding adding to container widths using the border-box method noted below:
http://www.paulirish.com/2012/box-sizing-border-box-ftw/
This makes layouts less of a headache. So instead of margin, set the width to 33% and add whatever padding you need to give space between the objects instead.
