Restoring a classic
Caporegime
25 Jul 2003
FR+UK
I'm thinking of buying a Triumph Spitfire, and restoring it. Only I'm not too hot a mechanic.
Has anyone done anything like this, and can you offer me any advice or tips? Any decent publications I should check out, etc?
Cheers in Advance.
Well, if you stick to something common like a Spit literally everything you could/would need is available to buy. If you can see about doing a course during the evenings at a local college if you want to improve your skills...ask them nicely and they might even let you take it there. As for reading, just look through the classic car mags that have readers cars sections in them...theres always splenty of tales of rot and horror to let you know what your getting into...
I'll post a bit later.
But be prepared to spend years doing it, ploughing a small fortune into it in parts, labour and tools and not getting anything back when you sell it.
Of course - there are different types of resto and that is the worst case scenario - a nice rolling restoration can be quite gratifying with good results :)
Two true, Ok I'm not the best at working on it often, But I Do plough a fair chunk of my annual leave into it every summer. Must be 2 years I've had it know ? anyone remember when I brought it.
All I can say is don't get a rusted out shell, That's what takes the time welding. If its just engines, suspension, interior ect ect then you'll be fine.
By no means do I regret it, far from it. But I was a little nieve on how long it anbd how hard it would take.
I went for the mechanically fine car which was rusted. I shouldn't of done it the other way around.
You will be if/when you finish it! If you are looking at restoring a classic car you will almost certainly need to do some welding, and possibly a LOT of welding depending on the car you buy. Mechanicals are fairly simple on older cars, but removing the rusted, seized nuts and bolts will require the right tools and some skill.
Fixing bodywork properly is probably one of the hardest skills to learn (and I don't mean welding half a baked bean tin into the body and covering it with 2 inches of filler!), but ultimately one of the most satisfying.
Cheers in Advance.
Hi there. Im hoping to embark on a similar road. I'm pretty new to any REAL mechanics but it was suggested in a post i started a while back that I get an old car and start to tinker.
Im getting my driveway coverted into a garage, I asked for tools for christmas and now im looking at project cars. Minis, midgets, spitfires, dolomites etc... I hope to post my findings on OcUK motors when the 'garage' is finished and i have my car. ;) :D
Best to get one that's driving and MOT'd for your first one. Then armed with a Haynes manual and some spanners you can learn to maintain it as you go.
Best to avoid a full on restoration for the first one because as said it's expensive, takes ages and is heartbreaking. It's taken so long I've completely lost interest in mine many times and had to just go away and come back later. With a better condition car in the first place you'll be out enjoying it on the road much sooner.
Once you're confident you can go for the full on weldathon
Check some pics of my Anglia from June 2005-present here and if you search for Anglia in this forum you should find my old posts with some explanations of what's going on. These should do the trick, looks like the oldest ones are gone though:
http://forums.overclockers.co.uk/showthread.php?t=17535368
http://forums.overclockers.co.uk/showthread.php?t=17541203
http://forums.overclockers.co.uk/showthread.php?t=17556476
http://forums.overclockers.co.uk/showthread.php?t=17573352
http://forums.overclockers.co.uk/showthread.php?t=17598570
http://forums.overclockers.co.uk/showthread.php?t=17613845
http://forums.overclockers.co.uk/showthread.php?t=17626399
Aye the reason I went for a Spitfire is that my car knowledge is pretty poor, so I thought the availability would help.
Its just something I fancy doing, always like Triumph's, and Ive got a fair wack of cash now and I'm not using it, so I figured..why not :)
Awesome, thanks for the advice Jonny.
Great think about the Spitfire (apart from the classic name!!) is the fact you can open the bonnet and sit on the front wheel to work on the car - thus saving lots of backache when "tinkering"..
It all comes down to budget really and what you want out of it - to start with why not get a runner that possibly you can tinker with and make better - from here you will learn more and more just from actually getting your hands dirty and your confidence will increase - therefore giving you the "balls" to try bigger jobs later on....
When I brought my first Mini 1275GT it was a runner but I hadnt yet passed my test (Im going back to mid 80's here) but still had a mate drive it back to my garage and gave it a full engine out rebuild, new wings, full respray in British Racing Green with White roof, 13" Revolution Alloys and other usual mini mods....
Its a great feeling when you rebuild something, then get it back out on the road...
Go for it mate.....good luck!
Pretty much any Triumph or MG is a decent choice as there are plenty of companies providing the parts, and plenty of clubs providing the knowledge. The club triumph forums are a mine of knowledge and, though not as easy to use, the Triumph Sports Six Club site is useful too.
eBay is always chock full of Spit bits making the restoration a bit more economical than some other models and marques.
Somebody once told me "buy the best bodywork and don't worry so much about the mechanics" which is decent advice. The less welding/bodywork you have to do the happier you will be and the less daunting the whole experience will be. Mechanicals are (relatively) much easier with only some parts requiring more specialist knowledge (like gearboxes, overdrives, some parts of the engine rebuild like boring, skiming, etc.) that you will probably have to pay for if you need it.
The spit is also nice as it's a chassis car, which means that you can whip the whole body off (he says, easier said than done ;)) and have a good look at the chassis, fixing any issues and making it easy to rustproof. You can also spray the body tub underneath in one go that way too, making a lot of the "awkward to get at" parts of repair/rustproofing more amenable.
The wiring is simple, the brakes purely mechanical, the suspension simple (although it can be difficult to set the geometry up if you haven't got the knowledge/tools/etc.) and so on. The interior is quite cheap to re-trim and there is a lot of tuning/customising support out there. For example, fitting MX-5 seats is a common job, most cars have tubular manifolds and sports exhausts, and so on.
Out of all the cars out there, the Spitfire has got to be very near the top of the "easy to restore" list.
