Moved in to our house in October of last year and we have some decking. Having never owned a house, let alone decking before my DIY knowledge is sorely lacking.
Was hoping some more knowledgeable people can help me.
I have some photos of the deck that you should be able to see here:
https://goo.gl/photos/PNTMU4QbNeufhwLm6
I don't know how long the deck has been there, how it has been treated in the past, or what it is made from!
I've had a look at the deck and some of the boards and are loose or cracked - the ones that made the step into the conservatory are failing and need to be replaced.
I've done some Googling about what to do , but wanted to get some additional consensus from here.
I think I need to something along the following
1) Clean the deck - with a brush to get rid of all of the debris
2) Use some deck cleaner to get rid of all of the gunk, and then use a pressure washer to clean off
3) Do I then need to strip the current stain on the deck?
3a) Replace the current decking that has issues - how do I get a like for like replacement, or doesn't it matter.
3b) I guess just using deck stripper is right, I couldn't sand down the entire thing, especially given it has grooves.
4) Restain the deck?
5) ???
6) Profit?
Any advice would be useful, I'm happy to do the work myself just need guidance on what to do. I wish there was a DIY consultancy service for someone to come out look and it all and tell me what to do!
5) ???
6) Profit?
