resuming from sleep sometimes causes my H60 to spin up too slow
16 Jan 2006
Evening.
First some findings from my second round of testing:
1. From a cold boot, my h60 pump, stock cooler and system fan always work as expected.
2. From a sleep/resume cycle my h60 pump runs around 1500 rpm instead of 4500rpm approx once in 20 sleep cycles.
3. From multiple sleep/resume tests, the system fan and stock CPU cooler always run at correct speed.
My BIOS is set to run the system fan (pump when using h60) at full speed.
Since upgrading to W10 my tmp sensors in hwmonitor now read the correct temps (they used to go to minus 127c after resuming from sleep)
Could my h60 really have a problem that only shows up from the occasional sleep cycle?
Thanks a lot
I thought this could
