Retail or OEM??
Status
Not open for further replies.
13 May 2007
West Yorkshire, UK
ok...i know its probs been asked a fair bit but neways....
whats the differance between vista retail n OEM ??
i had a site about the differances but cant find it :(
could any explain the differances???
The software is the same e.g. Ultimate v Ulimate, Home V Home, but the licence agreement on usage is different.
The main point is with the retail version you can install it as mainy time as you want on your PC, and you can change whatever hardware you want and re-install at any time.
With the OEM, there is a restriction in that once it's installed you in can't re-install it on your PC if you change your motherboard (or change you MB when it's installed) as when it registers with MS it registers details of your hardware.
There's been a number of discussion as to whether MS would actually enforce this as what would happen in the case of someone who has a MB changed due to a defect etc.
Burnsey is the man with all the details of the actual in's and out's of all of this.
Hope that helps.
Taff
The retail version you get a DVD with a few complimentary mints.
The OEM comes on 4,000 floppy disks.
gareth170 said:
so if u had a question that u want a answer too, would u like it if someone just be funny and didn't answer your question??
Get a grip man , he made a quip & it was funny & to be honest the original OP
needs to just type in ' search'for vista oem on these forums to find endless discussions on this subject. There's even another thread running on the same subject right now :rolleyes:
if u people thinked that was funny then u people really need to get out more...
PhillyDee said:
Why oh why does every "Which Vista, OEM or retail?" thread end in a flame war? I dont think ive seen one that hasnt.
Yes but the issue here isn't even about the original question LOL
icraig! get in the corner now - naughty boy
Status
