Retro CPU upgrade - is it worth it?
11 Dec 2005
Hi all, a slightly different question than most.
I'm currently running a somewhat old system by most standards on here - core2duo E6750 with a Radeon 4970 or something similar. Being strapped for cash, I was looking at getting a bit of a boost for as little £ as possible. Main uses are gaming (BF3 was the latest I've played, hopefully some more Civilization in the future if I can find the time).
I was thinking of getting an E8600 off fleabay, can pick one up for £30. Do you think the increase in performance would be noticeable. I think it's the CPU rather than gcard that's limiting things at the moment (some stutter on BF3 for example)
Thanks
Check your board supports them before ordering one, as not all boards support the 45nm processors.
Avoid the E8600 as being the fastest chip it commands a premium, the E8500 is probably better value and not much slower.
If you board is half decent, you should be able to overclock it over 3.5Ghz with little effort.
I went from an E5300 to a E8500 and the difference was definitely noticable, the bigger cache made some difference. I have since moved onto a Pentium Anniversary + cheapest Z97 board I could find, and the difference was even more immense (even keeping the same 4890 graphics card)
To be honest, I'd check your board and see if it will take C2Q. You can pick up a Q6600 forabout £30 these days. You'll see a much bigger improvement I think.
I've just upgraded a relative's PC from an E6400 to a Q6600, plus a used 240GB SSD that I picked up for £40, and 4GB of ram I had laying around. It's absolutely transformed it.
