My latest acquisition is an old Raleigh rod-braked roadster (I believe the DL-1 type). An online auction find, picked up last week. The blacked out chainwheel and brakes, together with the lack of date on the rear Sturmey Archer hub I believe means this is likely to be a wartime bike (assuming it still has its original back wheel!) Pictured below after 30 mins in the garage removing the front and rear fenders, and the hockey stick chainguard:
I'm not too bad with the spanners, and am quite happy maintaining and upgrading my current "fleet" of roadbikes, but I've never embarked on a project like this... The plan, as my first "restoration" type project is not for period authentic factory-fresh rebuild, but for a "path racer" style project inspired by those old Edwardian racers with the extremely slack frame angles... Think inverted north road/moustache handlebars, fixed gear, big cream tyres etc etc.
My inspiration has been https://www.lfgss.com/conversations/220415/ this thread over at LFGSS - and it's a similar look I'm going for.
I've deliberately not bought a mint condition bike for such an endeavour - the pictures make it look better than it is. The bike was originally red, it seems, and has been brush painted black with matte emulsion, which is slathered over everything, including the frame bolts and rod brake guides attached to the forks and chainstays. The chain guard was secured to the seat tube with a screw through a cable tie attached to a car engine hose jubilee clip...!
There's a bit of pondering to do... I'd like to keep the rod brakes, but the inverted handlebars which are key to the look I want won't fit with the roller brake levers. If I switch to cable/calliper brakes, I will need to drill the fork and buy some new wheels - losing a massive part of the originality of the bike. My preferred option is to keep my eye out for an old clip on "bobby dodger" style brake as the guy in the LFGSS thread used - that will let me keep the rod braked front, use a fixed gear on the back and keep the wheels.
Step one was the strip down. Luckily the seat tube had been greased, and the saddle came out easily. The handlebars took a bit more persuasion with some hammering on the underneath of the bars with the frame upside down in the workstand.
After a few days of spraying the cotter pins with penetrating oil, they were unexpectedly hassle free to remove - and came out with a few firm whacks on my improvised Sheldon Brown inspired setup above. The locknut on the threaded fork steerer was well and truly stuck, but a good path in some more penetrating oil and a massive 15" adjustable wrench borrowed from my other half's dad's awesome garage got that off. Interestingly, there aren't enough ball bearings in the races... maybe the bearings were caged and the plastic has totally dissolved???
State of play at the moment - everything aside from the bottom bracket is out (awaiting delivery of my special spanners for the adjustable cup and the lockring), and the wire brush attachment is on the drill for paint and surface rust removal. There's a bit of pitting down around the bottom bracket where the paint is flaking off easily, but it's not too bad.
Lots more parts to buy, lots of cleaning and painting to go, 2 wheels to learn to rebuild (3 speed hub > fixed on the back, and dyno hub > standard hub on the front), and I'm sure plenty of swearing and scuffed knuckles to go!
More photos as it progresses!
