Retrofit an integrated fridge?
6 Jan 2006
Newcastle upon Tyne
My office has a small kitchen with a separate freestanding fridge freezer. Is it possible to fit an integrated fridge into one of the cupboards? Or does it need to be a specific cabinet that houses the internal fridges?
Hope that makes sense!
It’ll certainly be possible. So long as the cupboard you plan to use has sufficient width to fit the integrated appliance and you don’t have one in mind that needs a particular type of door then it should work just fine.
Generally speaking most integrated appliances simply fit inside the cupboard using supplied brackets, then the door is fitted on the front of the appliance, again usually with supplied brackets / fittings.
