Return hose problem.
11 Jul 2003
Telford//west mids
Getting near ready to start a new build but my return hose will come out of my Phobya 480mm Quad Radiator placed at the front bottom of the Corsair 900D but I have a Koolance RP-452X2 Dual 5.25" Reservoir it will be up in the front bays down low as possible my question is im thinking of putting in a Bitspower Z-Multi 250mm Water Tank with the inside tube at the top so that I can have the water from the rad go into the rez then out the top and back into the bayrez that way I don't need to run as much hose.
Think that will be ok?
so you want to put in another reservoir instead of running longer hose?
i dont understand? is this a design thing?
Just thought the extra rez would take the strain off the pump,its just a idea for now may still run the hose up from the rad into the koolance rez just looking at the options.
the res takes D5's right?
they should be more than capable of that head height :)
