returned faulty card now nvida or radeon next
10 Jul 2008
suffolk
well i had to return my 3070 ti which was faulty now i dont know whether to go the same route or get a
https://www.overclockers.co.uk/asus...ddr6-pci-express-graphics-card-gx-458-as.html
looks a decent card and the 3070 ti worked ok but the fault put me of and the 6800xt is comparable and slightly better but who uses one for vr how do they cope
or should i stick with nvida
i use a quest 2 and like games like alyx and pop1
Stick with Nvidia if you are in VR a lot.
I hope this year sees graphics card stock return to normal. I'm fed up missing out on the 3080 FE at rrp of £650. Seeing all these 3080s and 6800XTs inflated to £1300 to take advantage of supply issues is shocking.
dunno what your budget is but its quite easy to get a 3080TI FE at msrp (about £1050) using Telegram signed up to FE Part Alert, i did it for my 3080TI FE. IIRC you do see 3080s on there too but they sell out in seconds, the 3080TI's last about 30 minutes, the 3090's last a couple of hours.
Might as well go for a 3090FE or 3080ti FE over paying inflated prices for AIB cards.
I've had my 3090FE for nearly a year, and though I winced at the price, I've had a full years use and I'm glad I'm not having to jump on alerts all the time.
Plus it's an awesome card of course.
