I need to return an Amazon order, fortunately my local corner shop is a Hermes Drop-off point. I don't have a printer at home so can choose this option on Amazon;
I'm assuming Amazon cover the cost here and there is no charge, just wanted to double check?
Thanks.
It says £0.00 on Amazon, but when double checking on Hermes here it says "Pay and print your label in seconds, from as little as £2.45"Hermes Drop Off - no printer required - £0.00
Your QR code will be emailed to you which you can then scan at the Print-In Store machine in your local ParcelShop. To find the nearest Hermes Drop off location where printing facilities are available, click here. Make sure you have the ‘Print label at ParcelShop’ selected when searching for the nearest Hermes Print facilities.
Thanks.
