Returning to PC gaming after a long hiatus. Will this build work?
8 Mar 2015
After a 5-year hiatus from gaming on a PC, I'm looking at getting a small form box that will serve as both a gaming machine and a general family PC for word processing and the odd bit of graphic design on Illustrator.
Specifically, I have been out of the loop for so long that I've no real idea where graphics cards have got to. I've got a lot of catching up to do and I'm most interested in playing games like Skyrim, Dawn of War 2, Portal 2, Diablo III, Total War etc. I may be interested in having a go on Eldar Scrolls online at some point in the future (or the new WH40k MMO!)
I haven't built a PC for years, so thought it would be safer to go for an OC spec build. How well would the following spec play the above games? Would you recommend a higher spec graphics card? Speakers and peripherals etc. are already owned.
YOUR BASKET
1 x OcUK Gamer Micro Xa - AMD FM2+ Micro ATX Gaming PC Configurator £683.18
- Asus PCE-N10 Network Adapter 150Mbps - PCI Express
- Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614)
- SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black
- OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
- Seagate Barracuda 1TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
- Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/120G)
- MSI GeForce GTX 750Ti OC 2048MB GDDR5 PCI-Express Graphics Card (N750Ti-2GD5/OCV1)
- Kingston HyperX 8GB (2x4GB) PC3-14900C9 1866MHz Dual Channel Kit - Black/Red (HX318C9BRK2/8-OC)
- Raijintek Themis Direct Contact CPU Cooler
- Gigabyte F2A58M-HD2 AMD A58 Chipset (Socket FM2+) DDR3 Micro ATX Motherboard
- AMD A6-6400K 3.90GHz (Socket FM2) APU Richland Dual Core Processor (AD640KOKHLBOX)
- BitFenix Prodigy M MATX Cube Case - Arctic White
Total : £692.78.
Many thanks!
Hi,
It looks under powered in the cpu department, are you sure you dont want to build a PC?
Could even ask OcUK to build a PC for a fee.
OK thx, my budget limit is £750, so assuming I'd get OC to build it, what system would you recommend? I could stretch the CPU to a AMD A10-7700K 3.40GHz (Socket FM2+) APU Quad Core Processor?
I wouldn't bother with AMD CPUs at all TBH, apart from that you're choosing an APU, you'll be using the graphics card so the APU on the chip will be redundant.
