Reusing old power supply for secondary pc build...modular cable help!
16 Oct 2007
Amongst my spares box I have a Corsair HX520 power supply.
I am using this for a new server build.
Problem is I don't have sll the modular Sata power cables that came with it.:(
Image of sockets on hx520 here.
http://www.overclockersclub.com/siteimages/articles/corsair_hx520w/a_backofpsu_thumb.jpg
My gpu is an amd Firepro 4900 which doesnt need a power connector.
On the psu theres two free 3x2 Pcie's and five 5x1 sockets...I need to fit 4 possibly 5 hard drives in there.
Had a look about cant see suitable cables for sale anywhere?
Any suggestions guys?
Would prefer not to buy a new PSU when this one is there.
Thanks. :)
Check out the Corsair cable upgrade kits, there is a smaller kit that can picked up for £20 - £25 depending on where you shop and what colour you want, have a google for the following product codes and you'll find them.. ;)
CP-8920006
CP-8920007
CP-8920008
..and so on... (HX520 model isn't specifically listed, but i assume it shares the same design as the larger models which are)..
