Reverb G2 owners, does this sim work?
20 Apr 2015
Wondering if any reverb G2 owners would mind giving this Apollo lunar module sim a whirl, just to see if it works?
Thanks.
http://www.eaglelander3d.com/downloads/ELVRF3.zip
IN-VR MENU
This menu appears as an extension of the DSKY in the center of the LM
cockpit.
RESTART + VERIFY = Reset scenario
RESET HEAD POSITION + VERIFY = Reset view in VR
SPOT VIEW + VERIFY = external view
PAUSE = Start flight / Pause flight
STOP/START MUSIC = Restarts music, does not stop it.
EXIT = Exit the simulator
OCULUS TOUCH (OT) HAND CONTROLLER FOR RIFT, RIFT S AND QUEST 1/2
If the 'in VR LM Attitude Controller Assembly (ACA) is used to control roll, pitch and yaw only.
First trigger fingers on both (OT) hand controllers and the right hand controller 'A' button.
'Rate of Descent' (ROD) DOWN ... Slows your rate of descent by 1 fps.
Right hand controller 'B' button and left hand controller 'Y' button.
Rate of Descent' (ROD) UP ... Increases your rate of descent by 1 fps.
If the 'in VR LM (ACA) is NOT used the left hand (OT) controller thumbstick is used to control roll and pitch.
Right hand controller 'A' button.
left hand controller first finger trigger yaws the LM to the left.
Right hand controller first finger trigger yaws the LM to the right.
EXTERNAL VIEWS
Both first finger triggers depressed at the same time, and the Touch
controllers moved closer together zooms in on the LM
controllers moved away from each other zooms out on the LM
Right trigger finger depressed and controller moved left/right/up/down
to pan left/right/up/down
OCULUS button = Exits the sim
KEYBOARD
<F3> = Reset head position
<F5> = Reset scenario
<P> = Start flight / Pause flight
<+> = 'Rate of Descent' (ROD) down ... Slows your rate of descent by 1 fps.
<-> = 'Rate of Descent' (ROD) up ... Increases your rate of descent by 1 fps.
<1> = Cockpit View
<7> = External view
<K> = Kill Engine
<A> = Abort Stage ... separates ascent and descent stages.
<X> = X-pointer toggle
