reverse DNS mapping? is it talktalk's fault?
21 May 2003
Hi. I'm at bristol uni and at home in rbistol (with daemon internet) I can ssh fine into Bristol's server.
When i tried it in london (using talktlak broadband) it kept saying connection closed. I e-mailed a tutor thinking the server's had been shut down, and he said "if the connection is closed, then that is because your ISP does not
prvoide a reverse DNS mapping". This guy is really clever but before I go on and move from talktlak to demon i just wnat to check that that is the only problem that could be cuasing this.
For example i'm yusing a differnet wireless route (belkin vs netgear) and am wondering if that could be anythin to do with ti.
thanks for any help.
Looks like an initial security measure to check a "proper" incoming IP address by its reverse DNS entry.
No reason to not believe the guy, why not check with Bristol Uni Network Support?
A lot of ISPs, including Demon, do provide reverse DNS entries, even dynamic addresses will have a placeholder hostname based on the IP address, just laziness if TalkTalk don't.
There's PLENTY of ISPs who don't have pointer records unless you tell them. Often it will take a while to be able to speak to someone who knows what you are talking about though :(
rudeboymcc said:
so you reckon i can call up talktalk and get them to enable it?
what exactly do i need to ask for?
LOL good luck, the average support guy wouldn't know an in.addr.arpa zonefile or PTR record if it jumped up a took a lump out of him!
HEADRAT
You may also have a PTR record which doesn't resolve back to your IP, or perhaps multiple PTR records.
It happens, I had a BT Business DSL connection once which had 2 different PTR records, one resolved back to my IP, one resolved to a different IP, so anything doing DNS checking immediately thought I was some dodgy spoofing haxor. :(
