We have just bought a reverse macro ring from the bay.
When i conect it up, and look through the view finder, it seems to work fine, the seen image is as expected, I have to focus manually as expected, no problems there.
But when I try and hit the shutter button and take a picture I get
!no lens attached
Doese any body know where I might be going wrong, or if there is a work around to make the camera believe there is a lens?
the camera is a minolta dynax 7d, using a minolta 28 - 100 55mm thread lens.
thanks in advance
!no lens attached
thanks in advance
