Reversing Cameras
19 Jan 2003
Bristol, UK
I am considering fitting a reversing camera to the van, it would be beneficial for parking.
Does anybody use a reversing camera? If so which model?
I would want something discrete. Fitting is no problem so don't necesarily need wireless (unless the wireless options work well?)
TIA
wouldnt use one even if I had it, granted I only have a transporter so its not 'that' big but you get to know how big your van is after not very long!
to summarise I would say no but its dependent on size of vehicle (I drive a 7.5m sprinter 311 for work as well and have no real issues parking that)
i dont think this thread was created for us to speculate if he needs one or not
Who says that he doesnt want one just for the fun of trying something new ?
in answer the the question you will probably need a headunit that supports VGA input and obviously either double din or with a fold out screen.
You'll then need to buy the reversting camera, but whever you buy the headunit from should be able to sell you one of these also.
No specific recommendations unfortunately, maybe ask at the shop where you're buying your head unit from for a demo ?
