I've put together a spec for a development workstation machine (no gaming) the requirements being six core CPU, two AMD GPUs (which I already have - dual and triple slot cards) and great airflow as the case is going to be running all the time and frequently under heavy cpu and gpu load but it would be nice to have it not too loud as it is operating in an office environment. The CPU will be auto-overclocked using the TPU switch and possibly asus suite. GPUs will also be overclocked using msi afterburner or catalyst control center.
I wanted you guys to have a look and suggest anything that occurs to you. I basically only have tonight to get some feedback as tomorrow I order. Thanks.
Anything I'm missing? I don't think a windowed panel or fan controller will be approved for purchase as it is non-essential.
- Fractal Design Arc Mid Tower Performance Case w/o PSU
- Asus P9X79 Deluxe, Intel X79, S 2011, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0 (x16), ATX
- Intel Core i7 3930K Enthusiast Unlocked, S 2011, Sandybridge-E, Six Core, 3.2GHz, 12MB Smart Cache, 130W, Retail
- Corsair H100i Hydro Series CPU Cooler, LGA 115x, 1366, and 2011 & AM2, AM3, FM1 and FM2
- 120mm Corsair Air Series SP120 Quiet Edition, High Pressure, 1450rpm, 37.85CFM, 23dB, 3-Pin, Twin Pack
- 140mm Corsair Air Series AF140 Quiet Edition, High Airflow & Low Noise, 1150rpm, 67.8CFM, 24dB, 3-Pin, Single Pack
- 240GB Corsair Force Series GS, 2.5" SSD, SATA III- 6Gb/s, SandForce 2200, MLC, Read 555MB/s, Write 525MB/s, 90k IOPS Max
- 27" Asus PB278Q LED Monitor Full HD HDMI/DP/DVI 2560x1440, 5ms, 300cd/m², 80000000:1, Speakers, Black
- 1200W Corsair Digital AX1200i Full Modular, 80 PLUS Platinum - 92% Eff', EPS 12V, 1 x 140mm Fan, ATX PSU
- 32GB (4x8GB) Corsair DDR3 Dominator GT, PC3-14900 (1866), Non-ECC Unbuffered, CAS 9-10-9-27, DHX Technology, XMP, 1.5V
- 2TB WD WD20EARX Caviar Green Quiet SATA 6Gb/s IntelliPower (5900rpm) 64MB Cache 8ms HDD OEM
- Microsoft Windows 7 Professional 64 Bit SP1, Operating System, Single, - OEM
- Samsung SH-224BB/RSMS 24x DVD±R, 8x DVD±DL, DVD+RW x8/-RW x6, x12 RAM, SATA, Retail
- Microsoft Wired Desktop 600 Black Keyboard with 3 Button Optical Mouse USB
- Arctic Silver 5 Thermal Compound for CPU and Chipset Coolers - 3.5 gram
