so wanted a custom PC upgrade. so after using overclockers custom service 2 times before it was a no brainier..
So worked on my spec, Wrote it all down in an email. (stock codes, Notes for engineers)
Phoned Overclockers, sent them the mail.
4 days later I received it.
I ordered
i7 5830K
ASUS x99 WS-E
32GB TeamGroup Elite Ram
1x 128GB SSD
Prolimeth CPU Cooler
1300w Superflower PSU
corsair 540 case
asked the engineer to route 2x 6 pin pci-e & fill all storage bays with sata/power
they did a almost perfect job! it was easy to add the the extras i already had
2x 980GTX
2 SSD's
Changed to Noctuas Fans
here is finished result.
only bad thing to say, is the cpu cooler does not allow me to use PCI-E slot 1 due to the cpu cooler size. i did choose this cooler so its my faulty. however it would been nice to be contacted as i would have probably bought a h100 to allow me to use slot 1
but to be fair thats 99.9% my fault
overall
+ cable management
+ fast neat and tidy
+ quality
+++ good packaging
+ would use again
- could have informed me of cpu cooler restrictions, could have bought an h100
I ordered
i7 5830K
ASUS x99 WS-E
1x 128GB SSD
corsair 540 case
2x 980GTX
2 SSD's
overall
+ cable management
+ quality
+++ good packaging
+ would use again
