Review this build
8 Aug 2012
Plymouth, UK
My basket at Overclockers UK:
Total: £718.90
(includes shipping: £0.00)
Hi all. Looking to make the Intel switch but in order to gain the funds I need to sell my old rig. So new build it is! Reckon I can get £600 optimistically for my old one as a whole. I'm current;y running an FX 8320 @ 4.2ghz and a 970 Stryx with 16gb Fury x
Can you take a look and fire across any recommendations?
You want a better power supply. The SuperFlower Golden Green HX 450W is only a few quid more.
I would also stick some faster ram in there as 2133MHz is pretty slow these days. A 2666MHz - 3000MHz would be ideal.
Maybe swap the GTX 970 for a GTX 1060 unless you are keeping it.
Also you need a cpu cooler as you don't get one with the 'k' cpu. Clearance in that case is limited to 130mm so you will either need a low profile cooler or a water cooler.
