Revised desktop build help
11 Jan 2011
Hi, i have revised my gaming desktop but i still need help deciding on a few things.
first off this is what im 100% happy with.
CPU - i7 2600K overclocked to 4.4 maybe slightly higher.
Motherboard - Asus P8P67 PRO or Asus P8P67 DELUXE
Memory - 8GB (2x4GB)
Video Card - Nvidia GTX 580 1.5GB
PSU - Corsair 850watts CMPSU-850HX
Hard Drive 1 - SSD 128GB
Hard Drive 2 - 2TB sata3
optical drive 1 - BluRay RW
optical drive 2 - DVDRW-CDRW
so i cant decide if i should go watercooled or aircooled?
cant decide on a case. looking for the smallest case possible i know this will depend on what cooling system i go for.
do you think aircooled will be ok even though i want to overclock?
is the Asus P8P67 DELUXE worth the extra money over the Asus P8P67 PRO?
if you think i should change anything can you let me know as im not really experienced with high end desktop builds and im only going off what i have read on various forums.
Matt
