Revo 3700 as a Media PC
16 Jan 2010
I've seen the Revo 3700's advertised at a very cheap price and have been looking for a Media PC for a while at this kind of price.
Has anybody had any experience with them?
Want something to be "always on", stream movies and also play youtube vids for my little one.
I also want it to run VM ware server with 2003 so I dont have to run my main PC all the time. Its only a backup Mail and nameserver so its not really used.
Any thoughts? Am I asking too much from a little box like this?
VMWARE will probably kill it stone dead if your pushing it with other apps at the same time, it really isn't what these little boxes were designed for! Do you really need a backup mail and nameserver in a home environment?
I have been looking to get an R3700 to use as a media pc as well. However I am looking at using XBMC with it. Could you please PM me where you have seen it advertised at a very cheap price please?
With respect to VMWare, I run it on my 4 year old Macbook (2GB RAM) without a problem but that is only using TinyXP and not server 2003..
I use the old R3600 its ok for torrents playing films in to tv but if you get the r3700 make sure you get the one with 4gig of memory as i had 1gig in mine and it struggled.
Its from a popular "e"lectronic buy-ing website. Isnt a patch on OC though.
I like to have control of at least one server for my domain services, so I have it at home. No need in having specific server hardware just for that. At present it only runs 256MB of ram and is rarely over 5% cpu on my current PC.
It comes with 2 gig, I would have thought that would be enough for WIN7 and VM.
Might just buy it anyway and see how it fairs.
I got mine last week, 4gb, win7 one.
Running xbmc on it and after all the updates and a very small amount of setting up it plays 1080 mkv's over the network no problems at all.
before i built my htpc i looked at these. then realised that running xbmc on it would be slow as anything and for a little extra i could get myself 4x the spec and actually do more then just movies on it.
i;ve been trying to sell my cracked case VIA Nano U2250 netbook on ebay, sold it for 150 and then had it sent back as they weren't happy with the speed, i was wondering not not use it as a nettop, as i need one
Is there any issue with using a netbook as a nettop, or do i need one of these dedicated machines?
xbmc is fine on the Acer Revo 3600 I have, doubt if you can get anything else that uses only 65watts of power or less though, so it's a little different to what you think, i.e. all to do with speed.
Unless it's using an ION GPU It's not going to be fast enough, It's the Nvidia ION that gives these Nettops the ability to play 1080p etc.
im yet to dive in on this but I see they have the ION2 chipset, from what I have read that should make quite a nice MPC?
This looks really nice, wouldn't mind one next to my tele.
Would be interested to hear from anyone with one, that or wait for a decent review to appear...
yes the whole 50p a year to my power bill, shucks how will i cope :rolleyes:
Does anyone actually KNOW the power consumption of this box, rather than posts above that suggest its very little?
It's no more than 13 watts at idle.
And FWIW my normal sized PC with a core duo only uses 60watts idle.
Currently using my revo 3700 with xbmc, no problems at all. I removed the Linspire linux and replaced it with Gentoo. Took a while to get the wi-fi working but aside from that runs like a dream and more or less silent.
