RGB Case Fan Recommendations - 120mm
  • Thread starter Thread starter f2t
  • Start date Start date
f2t
f2t
1 Aug 2010
I'm looking for 4 120mm RGB case fans and would be grateful for any recommendations. I would like ones that are quiet and ideally not too expensive...
They will be connected to a b450 tomahawk max so please include everything I will need to get them running as I have never installed fans before :)
I think the Lian Li UNI SL120 fans are pretty much the mutts nuts RGB fans these days.
Not the highest performers, but pretty decent and with some very unique features that put them well into the top end.
I'd get some myself if I hadn't already kitted my rig out with a dozen ML120s.
OK thats good to know, do I need to get a hub or any adapter cables to get them working?
Nope.
OCUK stock the 3-fan pack, so you just need a single fan to make up the four.
It looks like your board only has 12v RGB headers though, so you won't be able to use the Sync Motherboard feature, but you can still use the hub to control the fan speeds and lights.
The triple pack includes the hub and all necessary cables.
More about it all here:
https://www.lian-li.com/uni-fan/
