RGB Case Fans - which ones to go for?
6 Nov 2005
Newcastle,UK
Currently can't decide which ones I should go for, looking at
SP120
HD120
LL120
or the 140 variations of those.
Case is a Meshify S2, hence looking at both sizes.
Anyone with other recommendations and/or reasons for choosing one of the above?
Cheers
2x 140mm fans perform about the same as 3x 120mm fans of similar design and speed, also 140mm are usually quieter moving same amount of air .. so 140mm are better way forward.
Best fans don't have RGB in them, pluse they cost much less than RGB fans. OcUK has Ph-F140MP 2-pack for £16.26
https://www.overclockers.co.uk/two-...140mm-fan-radiator-performance-bu-003-pt.html
Paired with Phanteks Halos costing £10.99 each would give you good fans with RGB lighting.
Or buy some RBG lighting strips and install them. ;)
ML140 Pro RGB.
Reasons:
I've generally found the MLs to be exceptionally good fans.
140 is usually better than 120, if you're able to fit them.
Not a fan of RGB fans myself, but these do have RGB.
You made no mention, so presumably price is not a factor...?
You get an RGB kit with the fans, but if you want to control the RGB effects you can get the Corsair Commander which it all connects to. I use the commander, rgb kit and 8 Corsair ML140 Pro RGB fans along with the H115l Platinum cooler, love it. Have used Noctuas, Bequiet fans, and loads of different ones in the past, these are the best I have used to date.
The Meshify has a control panel on the back of the mobo tray, can all be controlled via Dragon Centre so just need the fans :)
