RGB Control Connection & Software Advice
2 Apr 2019
Hi all,
I have almost completed my first custom loop showpiece PC and am stuggling to work out how best to connect all my RGB peripherals.
I have an MSI Z390 Meg Mobo, 2 sticks of Corsair RGB ram, 6 x Corsair LL120 RGB Fans, Lian Li 011 Dynamic Razer Edition and a EKWB RGB Res, CPU and GPU loop.
The 6 Corsair fans are connected to the supplied Corsair RGB contoller that is then connected directly to the Mobo JCorsair header. The 3 EKWB units are connected to an RGB splitter that connects to one of the spare JRGB mobo connectors. And finally, the case connects to a spare USB header.
The 2 questions I have are, have I connected it all correctly or is there a better way AND what should I be using to control the mish-mash of RGB hardware? ICue for Corsair, Mystic for the MSI stuff, Synapse 3 for the O11 and whatever for the EKWB????
Ideally, i am looking for a blance between the least amount of cables and control software and the best result.
Thanks in advance
C
