RGB control?
11 Aug 2015
Is there any software I can get to change the colour of the fans in my Cooler Master 320 RGB case and the RGB on my Night Hawk RGB RAM? There is a controller, but it doesn't appear to do too much.
Edit: mobo is B550 Mortar
TIA
MSI dragon Center will take care of the RGB Ram Control (Did this myself last year) The case fans, you should be able to control the ARGB on them by plugging the ARGB controller into one of the 2 JRAINBOW 3 pin ports on the board, if I read the instructions right & said software should do the same.
