RGB Cooker advice
29 Dec 2007
Birmingham
Hi,
I might be being a bit daft here but I'm hoping you guys can clear something up for me...
I have just purchased the cooler master 240 RGB aio CPU cooler (www.overclockers.co.uk/cooler-master-masterliquid-ml240l-rgb-aio-cpu-cooler-240mm-hs-07p-cm.html) to go in a fractal meshify c. I plan on mounting the radiator to the top of the case and then buying another cooler master RGB fan as an exhaust. My issue is, I do not have an RGB header on my z170 board... I noticed that the aio comes with a controller which means I'll be fine with the two attached to the radiator but stuck with the exhaust. It's not clear from pictures and reviews but I was wondering, is it possible to attach more fans to that same controller?
TLDR: can I add more RGB fans to the AIO controller due to not having an RGB header?
Thanks,
Marc
