Hi Guys,
So the taking over of RGB continues as Corsair releases 2 new ranges of RGB fans. The HD120 comes with 12 individual lights allowing you to set them all to a different colour and the SP120 is RGB but can only be set to one colour of your liking.
The HD120 Fan Specification:
- Dimensions: 120 x 120 x 25
- Rated Voltage: 12v
- Speed: 800 - 1725 +/- 10%
- Airflow: 54.4 cfm
- Static Pressure: 2.25 mm-H2O
- Sound Level: 18 - 30 dBa
- Connection Cable: 4 pin
- PWM Control: Yes
- Bearing Type: Hydraulic
- Cable Length: 600mm
The SP120 Fan Specification:
- Speed: 1400 +/- 10%
- Airflow: 52 cfm
- Static Pressure: 1.45 mm-H2O
- Sound Level: 26 dBa
- Connection Cable: 3 pin
- PWM Control: No
All fans are expected to land in stock Week commencing 12th September.
Corsair HD120 RGB LED 120mm High Performance PWM Fan (No Controller) @ £22.99 inc VAT https://www.overclockers.co.uk/cors...formance-pwm-fan-no-controller-fg-061-cs.html
Corsair HD120 RGB LED 120mm High Performance PWM Fan, Single Fan, No Controller
Only £22.99 inc VAT.
ORDER NOW
Corsair HD120 RGB LED 120mm High Performance PWM Fan (Includes Controller) @ £32.99 inc VAT https://www.overclockers.co.uk/cors...ce-pwm-fan-includes-controller-fg-062-cs.html
Corsair HD120 RGB LED 120mm High Performance PWM Fan, Single Fan, Includes Controller
Only £32.99 inc VAT.
ORDER NOW
Corsair HD120 RGB LED 120mm High Performance PWM x 3 Fan Pack (Includes Controller) @ £69.95 inc VAT https://www.overclockers.co.uk/cors...3-fan-pack-includes-controller-fg-063-cs.html
Corsair HD120 RGB LED 120mm High Performance PWM Fan, Triple Fan Pack, Includes Controller
Only £69.95 inc VAT.
ORDER NOW
Corsair SP120 RGB LED 120mm High Performance Fan (No Controller) @ £16.99 inc VAT https://www.overclockers.co.uk/cors...-performance-fan-no-controller-fg-064-cs.html
Corsair SP120 RGB LED 120mm High Performance Fan, Single Fan, No Controller
Only £16.99 inc VAT.
ORDER NOW
Corsair SP120 RGB LED 120mm High Performance Fan (Includes Controller) @ £26.99 inc VAT https://www.overclockers.co.uk/cors...rmance-fan-includes-controller-fg-065-cs.html
Corsair SP120 RGB LED 120mm High Performance Fan, Single Fan, Includes Controller
Only £26.99 inc VAT.
ORDER NOW
Corsair SP120 RGB LED 120mm High Performance 3 x Fan Pack (Includes Controller) @ £51.95 inc VAT https://www.overclockers.co.uk/cors...x-fan-pack-includes-controller-fg-066-cs.html
Corsair SP120 RGB LED 120mm High Performance Fan, Triple Fan, Includes Controller
Only £51.95 inc VAT.
ORDER NOW
- Airflow: 54.4 cfm
- PWM Control: Yes
- Airflow: 52 cfm
- PWM Control: No
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
