Hi,
I’m new to all this and the help I’ve received so far from this community has really helped a lot so thank you. I have 1 more thing that I’d like help with if possible that’s confusing me. I have 4 case fans in my new case and 3 of them I installed myself and have used the BIOS to sort the curve, however 1 of the cases came pre-installed with the case and is RGB and was already wired up to the front panel connector cables. The cable has 2 connectors on it. 1 has the 4 female plugs with grab pins on either side and has a clip in the centre, which plugs into a cable that is wired up to the front panel. I can not control the fan speed on this fan because it’s not connected to the BIOS. I don’t have any fan headers left on my motherboard and I’ve been using splitters to connect my other fans but connector from the RGB fan won’t connect to the splitter because it’s not the right connection. I’m happy to lose the RGB side of it if it means I can control the fan speed. Can anyone help me please?
