RGB fan help.
18 Jun 2018
Hi Guys,
Recently ordered all my new parts and put it together.
The board is a b550 carbon WiFi and the case is a MSI Gungir 110R.
The issue im having is the fans are lit up but in red only, i have downloaded the Msi dragon center but can't change the led colour on these. They are currenly plugged into system fan 1-6.
Are these plugged into to the incorrect thing to control these?
Thanks
From the manual:
LED effects: Short press the LED switch button to change up to 26 modes. Press and hold the LED switch for 3 seconds the LED flash white light once, and then into the MSI motherboard Mystic Light synchronization mode. Short press once to back to the Hub control mode.
Did you plug the rgb cable into the relevant port on the MB as well from the fans/controller?
