rgb fan help
28 Jan 2015
Im looking for fans- 2x140mm, with rgb being used for intake fans on the bottom of a Fractal Torrent case plus a rear 120mm exhaust. This is for a build for my daughter- it currently has sone noctua fans and some old coolermaster light ring thingies on the fans but none of them match in colour as a mixture of Argb & Drgb all being controlled by Gigabyte fusion RGB which is fine.Motherboard has enough argb headers I think
any ideas for fans with simple cables- case has an Octo controller for the fans but I not want to go down the Aquacomputer rabbit hole again as the case simply is not big enough for all the leads and cables
Black fans as well ideally
Thanks for help
Thanks for help
I just changed all my fans from Lian Li to EK fans, they daisy chain together but with a cable which is quite easy to hide and then just end up with 1 cable running to the motherboard or whatever you are going to use to control them, which then slipts into 2, one for RGB and one for PWM.
These ones: https://www.overclockers.co.uk/ek-w...-rgb-400-1800rpm-pwm-fan-black-fg-018-ek.html
I brought these too as I needed 140mm too, but the colours match the 120mm, just hoping they release 140mm versions of the 120mm Quantum Impulse: https://www.overclockers.co.uk/ek-w...-static-pressure-600-2200rpm-b-fg-016-ek.html
They look great too, you get a true brilliant white out of them unlike with the Lian Li fans I had which was like a yellow'ish white, like 10 year old white gloss paint.
I was going to go for the Phanteks D30 fans which are available in 120mm and 140mm but they are 30mm thick, too thick, they wouldnt fit where I need them.
