RGB Fan Recommendation
15 Sep 2011
I have a Tomahawk Max mobo and did not realise the compatibility issues with the Corsair RGB fans - I only have 1x rear 120mm fan and would like to replace it for something which doesn't require me to buy a load of controllers. I can then plug it into the 2nd RGB header and control everything through MysticLight. Any recommendations? Under £20!
Hi,
No I don't think you are as I'm wondering the same thing as you. Not trying to over take your thread but definitely interested to see what people are suggesting for RGB fans performance to noise ratio..... with the same mobo!
