- 15 Apr 2019
My case and CPU cooler RGB fans don't see to be visible for any settings. I'm trying to change the RGB settings for them, but it's as if they aren't there. Currently they are functioning with the default rainbow colors cycling.
Originally I installed and used the Gigabyte control center, and RGB fusion. I had them working on there for a time, but then they disappeared. I have since uninstalled and reinstalled GCC a couple times, RGB fusion as well with no change.
Anyone have any suggestions for a solution?
Case: Lian Li LANCOOL 216 RGB ATX Mid Tower Case
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM
Motherboard: Gigabyte B650 AORUS ELITE AX V2 ATX AM5
