New build in a 011-D is completed, but it is a bit dark and dull when viewed through the side window.
Looking at either RGB strips and/or RGB fans to brighten things up.
Couple of questions on the fans:
Thanks,
Rich
PS. Also looking at this as an option:
https://www.overclockers.co.uk/phanteks-multicolor-magnetic-rgb-led-strip-2-metres-ca-007-pt.html
https://www.overclockers.co.uk/phanteks-rgb-led-adapter-cable-ca-057-pt.html
- Are there any RGB fans which illumate when used as intakes rather than exhausts?
- Are there any manufacteres who offer non RGB varients (I have push pull on 360mm rads, so seems pointless to have RGB fans which are hidden, but I would prefer to have matched fans performing both the push and the pull).
Thanks,
Rich
