- 1 Jan 2021
Hey guys,
Does anyone know how safe it is to use a 5v RGB JRainbow connector without pin 4 (ground)?
I’ve not spoke to OCUK yet (brand new board) - When I gently put the cable on the header, it was quite wobbly so took it out to check and noticed the 4th pin was really short on the header - most of it appears to be inside the connector as there was no metal laying around. I'm confident I didn’t handle it wrong, it’s as if the pin was brittle - or the connector in the cable faulty.
This will connect through a ARGB controller that comes with the Silverstone RVZ03B-ARGB case. The board is grounded to the case I think. Page 15 in this guide talks about Silverstone’s ARGB connectivity through their custom controller.
https://www.silverstonetek.com/m/rvz03-argb/RVZ03-ARGB-Manual-EN.pdf
