RGB Keyboard whine/buzzing.
25 Feb 2015
Hey,
I've just bought my first RGB keyboard (Razer Hunstman V2 TKL with red switches) and while i was using my pc i noticed a buzzing sound. I put my ear next the keyboard and found it was coming from there. It's quite annoying while sitting in a quiet room. The only way to fix this is either turn off the RGB or change the colour to static white at 100% brightness.
Is this a common thing with RGB keyboards? I'm not sure if I should return it or not as I'm worried i could buy something else that has a similar issue. I'm using it with the static white for now.
Has anyone else had this and are there any good keyboards you could recommend that are completely silent?
Thanks
I have way too many keyboards, and I have never encountered this, though I have never bought a razer one as I had issues with one of their mice years ago they refused to address so avoid their stuff now.
I would return it, its not a normal thing.
Thanks. I have just arranged a return.
I was thinking of keeping it and using it with just the static white colour as I quite liked it other than the whining sound but I know I'll never be able to use the RGB properly without it annoying me.
Guess I'll start looking for something else now.
