RGB LED case lights
10 Jan 2006
Scotland
OK so I have never had any lighting in any case before and I am thinking about some simple RGB LED lighting in my Meshify C (dark tempered glass panel), nothing OTT just like 1 strip to accent the motherboard lighting perhaps.
I have a MSI B450 Tomahawk board, which has 2 RGB LED connectors, which connect to "5050 RGB LED strips 12V". Is it simply just a case of buying any old RGB lighting strip so long as its 5050 and 12v or should I avoid the cheapo stuff in case of issues? As I say, never had any so haven't a clue if spending a bit more is actually worthwhile in terms of not going on fire, etc :)
Would this be what I need, I like that its magnetic? https://www.overclockers.co.uk/cablemod-widebeam-magnetic-rgb-led-strip-30cm-15-leds-cm-137-cm.html
