So, I find it interesting how quickly the RGB lighting scene exploded. I found the WS2811/WS2812 addressable (pixel) LEDs through electronics and build a few controllers for the them using AVR micro-controllers (used in the Arduino).
However in context of PCs I find they are often very expensive or require rubbish control software.
I got to thinking about translating my electronics LED skills into producing something for my PC.
Would anyone find an LED strip thermometer useful?
What about an LED strip air flow meter?
Or both?
Sound level meter?
I'm thinking about something that has little or no software requirement. The thermometer version would have a trim pot to calibrate the display to the temperature you desire and maybe a button to switch between bar graph, solid, breathing, etc.
Similar for the air flow meter.
They would only require a 5V or 12V rail which can be found on most motherboards, even if you just used an unused fan header, so they will not require BIOS control or even an RGB compatible motherboard. A 12V down to 5V adapter is easily possible for powering off SATA or Molex 12V rails... if not using 12V LED strips.
I am thinking about making these open source projects, but might also sell blank boards or even built boards. But the schematics, PCB layout, bill of materials would all be published online so people can customise them.
Anyone interested in helping with some ideas towards requirements?
Or both?
Sound level meter?
