RGB lighting for dual Monitors recommendations?
9 Mar 2006
London
Hi all I'm looking into adding some rgb lighting to my dual monitors got a set of 27" LG27GP850-B's both on a dual monitor arm what would anybody recommend?
I was thinking some Govee plus light bars as I don't want a led strip spanning across two monitors not sure how the light would cover such a large space though and don't want two seperate strips on each monitor as would like them to sync together and alexa activation would be nice.
My walls are white and my apartment is actually has very little Daylight that comes in so that will help.
Thanks guys
Are you looking for something with "ambilight" functionality which will reflect what's on screen, or just some backlighting?
If the former, then I've tried several options - made a thread on it here, but TL;DR - the only realistic option I've found for what you want is Hue Play bars; not the cheapest, but definitely the best performing (particularly if you want Alexa integration).
You'd probably want 4 or 6, 1 on the "outer" edge of each monitor, and then 1 on the top of each (and possibly 1 on the bottom of each)
