Hi all,
Sorry if this is the wrong place for this thread. I am a bit unsure about RGB systems and wondering if anyone can help.
I have 2 Antec Prizm 140mm fans at the front of my case which are connected to the antec fan/RGB controller. The connection from this has a 3 pin ARGB connector (female).
I was also lucky enough to get one of the Sapphire 6700XT cards in the recent drop which have a 3 pin male ARGB connector.
My motherboard is the asrock AB350M pro 4 motherboard, which has a 4 pin RGB header.
So basically I have 3 pin adapters on my graphics card and fan controller, but only a 4 pin header on my motherboard. I've tried searching but not found anything conclusive - is there anyway I can link these together to allow me to control all RGB lighting through one system?
If it makes any difference I'm not after crazy LED lighting, I would just like it to be easier to switch on/off and show the same colours.
