RGB lights
27 Mar 2016
Bristolian living in Swindon
Hi all
I know there's a lot of hate on here for RGB Lighting but I'm going for it :p
What kits or strips would you recommend?
My motherboard is a MSI B450 Mortar Max which has a couple of JRGB 4 pin headers (if that's any help)
Cheers
5050 RGB strip will work fine connecting to those motherboard headers, will all sync up.
I personally use Nanoxia Rigid RGB strips, extremely bright compared to normal flexible RGB strips I have used and up there with my Darkside rigid RGB strips. A pair of these (look around) will light up most cases very well.
The nanoxia stuff and normal 5050 stuff will connect to your board fine without going down propiroty route (like Corsair stuff) and sync with your mobo.
I got the corsair lighting kit. It works well with the commander pro I already had for fan management. I appreciate proprietary tech can be a pain, but from what I can tell there is no set standard anyway
