Bought myself an extra Corsair sp120 rgb pro fan ,didnt realise ive not got enough pin adaptors on my motherboard to fit it in ,already have the commander attached to other fans and rgb strip lighting
It comes with two connections ,so i can get the rgb bit to work ?
Can you buy like and extension or is there another way ?
Thank you
Thank you
