- 27 Jul 2006
- Huddersfield
OK so the plan was to use my new cases RGB fans and bits as the baseline for fitting RGB fans throughout the case and having a nice looking lightbox on my desk.
The case is the Corsair Crystal 280X and it comes with two of there 120mm LL fans and some kind of control brick.
However when looking online to find information about matching fans, if i could use other brands of rgb, getting it set up ive found that the softwear that corsair use ICUE is almost universaly hated as being buggy as hell.
So now im not sure what to do, ive never done any RGB in a case, let alone the amount i was thinking of throwing in the case. So i could use some advice.
What id like are 6 fans that are all linked showing the same pattern or working together with some kind of crawling pattern through them. I was going to have 2 fans at the bottom of the case and 2 at the front pulling air in, and then 2 at the top expeling. For a total of 6 Fans, eithr 120mm or 140mm. The top fans may end up being part of an aio if i dont decide on an air cooler.
In case it matters im getting the Aorus X570i Pro Wifi motherboard.
I do hope someone can help.
Thanks Brian.
Thanks Brian.
