- 7 Jan 2009
Hey,
Recently changed to a mini itx system.
Motherboard is Gigabyte x570i Aurus Pro WiFi.
Now I'm in a bit of a pickle, the issue been my motherboard (like many, if not all that I've seen in mini itx form factor ) only has 1x F_USB connector.
Now my cpu cooler is a Aorus ATC800 which has 4 pin fan connector & F_USB connector. (for thr rgb)
My fans which are Sp140 RGB Pro fan kit which comes with the lighting node core also requires 1x F_USB.
What can I do to resolve this issue so I can have all the RGB running?
The fan kit isn't an issue if I plug that into the only available F_USB then my fans rbg works, but that would leave my cpu cooler with absolutely no rgb at all lol
Is there any work arounds or adapters?
Bloody stupid they only put 1x F_USB port on the mini itx board's.
Appreciate any replies
