RGB Splitter Cable for iCue
9 May 2010
Cornwall
I have the iCue 7000x case and I have put three new (QL_rgb) fans onto my radiator to create a push pull. The case already has 4 HD_rgb fans. The case also has the iCue commander Core XT to connect the PWM and RGB headers, I have powered all 10 fans and I have 6 of the 7 fans lit up.
What I need, and have difficulty finding, is a split cable that will allow me to have all 7 fans lit up. Can anyone point me to a cable that will connect to the commander and allow two fans to light up from the one commander socket.
I don't quite understand, Commander core supports 6 RGB hub, each RGB hub supports 6 RGB devices.
You effectively have 36 RGB sockets for fans and stuff?
There are splitters you can buy on ebay for corsair rgb splitters but they risk burning out the RGB hub due to over current.
So, I should just plug the RGB hub that comes with the new fans into the Main commander in the case and use a fan PWM to power that hub!
If so, thanks, I did not know that.
Yep, main commander is Powered, and I see the new RGB hub also has a SATA power connector. Looks like I am back in the case today then.
