RGB strip help
I think you need to daisy chain the strips with the Fan Halo's to be able to control them with the case button. That way they will match the colour of the fans. Alternatively use the adaptors provided and plug them into the four pin ARGB headers on your motherboard, you can also do this with the Halo's.
They are rather tight not supplying a Halo for the rear fan!!
You were right. I removed the metal side plate of the case and the RGB plugs were not connected. plugged them in and now the lights all work. many thanks for the help.
