Rice in vents - help!
Depending on exactly where the rice has settled there may be a pollen filter or similar that you can remove which will give you some access into the lower areas of the ducting without having to take the whole dash apart.
I had this problem once, it was back in 1969 and me a good buddy were on a drive through a little village area known as Phu Bai Valley, when we got our jeep stuck in a rice field.
I found the best way to fix it was not to remove the rice but cook it right in the vent (using a spare flamethrower of course) and pick it out with some chop sticks we found sitting about.
Get one of these
Opps my bad
Oh well swap white for brown less visible
